Post new topic Reply to topic  [ 633 posts ]  Go to page Previous  1 ... 38, 39, 40, 41, 42, 43  Next
 Post subject: Re: Tremec TKO 600
 Post Posted: Fri May 14, 2010 10:22 pm
Purchased some cheap sheet metal from Lowes. Made a template out of cardboard. Transfer to sheet metal. Cut to desired size.
Mark for gauges. Cut out with dremel.
Clean it, prep it, and paint it your favorite color.
Make sure everything fits and looks just the way you like it.
Wire it in and screw it in place. Take it for a drive, its better then factory and looks sorta cool too.
-Jeff-
1979 Malibu 496 TKO-600 9"
- If wishes were horses, beggars would ride -
 Post Posted: Sun May 16, 2010 12:29 pm
Looks good. Thanks
 Post Posted: Mon May 24, 2010 7:54 pm
Tubage,
I had to cut the crossmember to make the 454 fit and give me enough angle for the TKO and driveshaft pinion angles.
I used a sawzall and took it a local welder. Works just fine.
-Jeff-
 Post Posted: Tue May 25, 2010 8:24 am
Thanks Jeff. How much clearance would you say you have now? Chris
 Post Posted: Tue May 25, 2010 5:51 pm
I can rock the engine back to a fairly incredible angle. As a matter of fact I have used a floor jack to 'force' the engine to rock back as I have the solid mounts and they dont allow for the motor to move enough. I used a fairly dramatic angle to get the tranny to line up real easy. Not sure it was very good for the motor mounts, but I no longer care and do what needs to be done to make my car work.
If you look at my cluttered photo you can see the jack holding up the engine under the balancer and the oil pan and how it fits in the notched crossmember. There is more than 1" of additional clearance if I needed it.
-Jeff-
 Post Posted: Tue May 25, 2010 10:09 pm
I ordered a moroso 20412 for an A body with extra crossmember clearance. Chris
 Post Posted: Tue Oct 12, 2010 9:54 pm
Looks like all my pics have been killed off by Charter.
I will need to spend some time fixing everything again now that I have a new internet provider.
-Jeff-
 Post Posted: Wed Oct 13, 2010 4:07 am
did you get her running again?
1980 Malibu BBC T-56 9"
1986 Oldsmobile Cutlass.
 Post Posted: Wed Oct 13, 2010 8:00 am
Running? I just took her on a 700 mile journey. Bangin gears and beatin the crap outta her. She runs alright!
-Jeff-
 Post Posted: Wed Oct 13, 2010 9:34 am
Where's the 'Like' button? :lol: :D
MR.com Facebook page
'87 Fiero GT - 2.8/5-speed
 Post Posted: Wed Oct 13, 2010 3:16 pm
sweeet
 Post Posted: Tue Jan 04, 2011 9:38 pm
Still running. Turning 12.20s on street tires at 116mph.
Still trying to get my pics sorted out so I can get this thread back to the way it was.
I love beating this transmission.
-Jeff-
 Post Posted: Sun Jan 16, 2011 11:37 am
Keisler new trans.....they except TKO trade ins
http://www.keislerauto.com/recent-news/ ... -cars.html
 Post Posted: Sun Jan 16, 2011 12:01 pm
I saw that a couple weeks ago... I want it, I want it, I want it, I want it, I want it, I want it, I want it.
But how much? I'm so lazy and don't like to pick up the phone to call them to ask just one question.
1978 El Camino
350, Dart Iron heads, Edelbrock intake and carb, TH350, Electric Fan, Powertrax Locker
1983 Olds Cutlass Superme - SOLD
SBC 350 260 hp crate engine w/ serpentine kit, TH350, all the usual bolt-ons...
 Post Posted: Sun Jan 16, 2011 12:08 pm
Cool :D I like it.
I did a little looking, had to do a double take because I know I hadn't seen this, or asked about it :lol: $1400 for just the trans (likely just the RS400, probably +$700 for the RS600) is very tempting.
http://www.pro-touring.com/showthread.p ... post756432
If you figure $1400 for the RS400, then add $900 to make it a 'PerfectFit' kit, makes you wonder if you could source some of the parts yourself (i.e. crossmember, driveshaft, etc... at least doing the driveshaft/clutch yourself) and come out paying quite a bit less.
