Post new topic Reply to topic  [ 5 posts ]
 Post Posted: Mon Dec 08, 2014 5:36 pm
Looking to get a new ultra holley Dominator 1150. Right now I have a 1050 3 circuit but this spring going to install a new trans with a brake , so is a 2 circuit or 3 better, for the brake? Specs 540 BBC afr 325 heads solid roller cam 3800 stall, 350 gear.
 Post Posted: Thu Dec 11, 2014 11:07 pm
I may be wrong, but if you're leaving on a trans brake, you're already at WOT, so unless the car will be expected to be street driven I would think you can save the money and just get a 2 circuit.
 Post Posted: Fri Dec 12, 2014 12:14 pm
I have a 3 circuit 1150 on mine. But what is the rest of the combo? Why is the converter stall so low?
http://s30.photobucket.com/albums/c306/ ... C01615.jpg
My old 78
http://s30.photobucket.com/albums/c306/ ... usquet.jpg
 Post Posted: Sun Dec 14, 2014 5:55 pm
I've never run a 2 circuit dominator, all have been 3 circuit. I've used from a 1050 to a 1250 to a 2.40" billet main body dominator.
 Post Posted: Thu Jun 04, 2015 8:10 am
Pro systems has a good write up on 2 vs 3 circuit carbs. Started with a 3 circuit gas carb on my car and went to a 2 circuit sv1 alky carb and did not tell much if any difference on the brake.
http://www.prosystemsracing.com/gurus.html
1987 Monte Carlo aero coupe on Alky
ET to be determined
cron
