Putting a M21 behind a SBC in an 84 monte. Currently have Shoenfeld 1 3/4" primaries to 3" collector. Looking to do the same 1 3/4" to 3" or even a 1 7/8" to 3". Anyone have any suggestions on longtubes out there in that size range that allow Z bar clearance?
These S/B Chevy headers are a shorty design that give maximum ground clearance and work with floor-shift manual transmissions only. Features 1-5/8" primary tubes and 3" collectors. Built with surface machined thick steel flanges for a great seal and mandrel bent mild steel tubing. Headers come...
I got it worked out. I wound up using the Schoenfelds I already had and just cutting off the number 3 tube that ran were the Z bar is and moving it between the number 2 and 4 tubes. Works like a champ.
