th-200 removal
tommi3520
54
Hey guys, i dont have the manual so if sombody has step to step guide for the 200 trans removal in a 1979 2 door malibu i would be really grateful to have!
im swapping it out for a th-350 and i´ll connect a b&m shifter to it.
greetings from iceland
Tomas
SSedan64
948
MACON, GA.
This is for swapping a 200-4R but will give you what's needed.
http://www.turbobuick.com/forums/threads/swap-write-up.377918/
You will need to run a line from the Intake for the TH350's vacuum Modulator. Also a Detent cable is needed if you want passing gear to work without manually down shifting.
