what shifter you using with a T56
Ray396
113
Middle Village,NY
Hi, I have a 86 Monte SS, doing the T56 swap. Wondering what shifter you guy's are using. I have 60/40 split bench. I have the Camaro shifter and it hits the pass seat. Just trying to see before I order anything.Thanks Ray
TURNA
6,028
Socialist NY
would something like this work?
images
TURNA
6,028
Socialist NY
That shifter is made for a 55-57 with a bench.
Your best bet is to make a pattern with a wire hanger. Then hit the swap meets at Belmont etc.
If you have a torch you could alway heat up and bend what you have now to make it work.
If you have or know someone with a welder you can do this
Also another nice option is to notch the bench seat or replace it with a notched bench seat.
Something like this
TURNA
6,028
Socialist NY
Keep in mind since you already have a 60/40 split.
Installing a set of Monte / G-body bucket seats is a simple bolt in because you already have the inner mounts on the floor board.
Might be another option foe you.
4,665
32
That was the shifter that I made to fit the bench seat in my wagon. I still cut a notch in the steel base of the seat frame to help the fit, but did not modify the upholstery.
To start with, I disassembled the shifter base and rotated the shaft 180 degrees so it faced forward.
