OK all you glide experts! I have a few questions...
Just got my car (not complete) and it came with a glide that was (is) supposed to have a manual valve body and a brake. First off when I looked at the transmission, it had no electric solenoid sticking out of it... so I am assuming, no brake. It has been a looong time since I worked on a glide, did they not from stock have a kickdown lever that ran in through the shifter lever? This transmission doesn't, so again I assume... maybe it has had the valve body changed. Any thoughts??? If I pull the pan, can I tell somehow if it is a manual valve body?
