cruising rpm question?
mobileaudio25
357
columbus ohio
I'm going to be running 245/40/17 tires, 373imited slip posi with turbo 350 and a mild cam. My mechanic said I needed around a 2400 stall due to my converter, concluding that I have roughly a 475 lift. Does this sound correct? And what can I expect to be cruising at 65 mph? Does this set up sound ok?
SSedan64
948
MACON, GA.
The Cam's Lift doesn't figure into Stall or Cruise rpm, the Cam's Duration & Operating Range will.
What is your Cam's specs, Part#? Duration @.050 Lift?
At 65mph = 3300rpm if you had a Lockup TC/TorqueConverter, add about 200-300rpm for TC slippage, so 3500-3600rpm @65mph.
245/40/17 Tire is 24.70" Tall
TH350 Gears:
1st = 2.52
2nd = 1.52
3rd = 1.00
A MPH Calculator from RPM and Gearing >> http://hotrodworks.net/hotrodmath/quarter.html
Gear/MPH Calculator >> http://www.f-body.org/gears/
A TH2004R would be a better option for crusing. It's .67/4th Gear and Lockup TC would drop the cruise RPM down to 2200rpm @65mph.
TH2004R Gears:
1st = 2.74
2nd = 1.57
3rd = 1.00
4th = 0.67
shvrolay
3.73 + TH350 @ 65mph is going to be roughly 3K rpm. + or - some depending on tire size.
