my bu has been sitting for 2 years and i got it out today and when i rev it up it lunges forward in park and neutral and will not go into reverse at all but it takes all 3 forward gears perfect. what could this be bad seals maybe?
TH350 Trans?
Sounds like the Forward Clutch is not releasing, this will also cause no Reverse.
Check the Manual linkage adjustment 1st. You can try disconnecting the Shifter linkage/cable and shift the Trans into gear by hand to see if it changes. On Jack Stands with E-Brake applied to see if the Engine rpm drops in Neutral.
