th350 help please
sb454chevy
211
L.I. new york
www.myspace.com
i have a manual valve body th350 and when i put it from neutral to 1st it make a terrible clicking or clunking sound. but if i put it from neutral to reverse it doesnt make any sound. does anyone have any idea what this could be? the driveshaft looks good but i am going to pull it out tomorrow to double check it.
i was told it might be that the case is worn inside and i can put a case saver in. how true is this and how strong is this? it is in a low 11 second car and i dont want it breaking if i use one
any help would be great thanks
SSedan64
948
MACON, GA.
There are 2 different ones, one is a small cheap spring & Tab and one is a Modded Support, much better but not cheap, used for severe wear & strength, requires other parts as well.
Part #413 & #824>> http://www.automaticchoice.com/Catalogue/th350.pdf and here > http://adapt-a-case.com/a74761dac.html
More Info here on the 2 cheap pieces 'Anti Clunk Spring & Case Saver' >> http://www.crankshaftcoalition.com/wiki/T-350_Rebuild_tech
sb454chevy
211
L.I. new york
www.myspace.com
ok so i got the drive shaft out there is no play but it does bind up so i am going to start there. i dont see how that can make the clunk-click sound that i am hearing but i am really hoping thats it.
LETSDRG
79
Grosse Ile, MI
I DO NOT recommend the screw on plate. i had this in my trans and the screws backed out and ate up the case. be careful. and yes they were lock tited and all...
sb454chevy
211
L.I. new york
www.myspace.com
ok so it is the case. how bad can it get? i am going to the track sunday and i am going to try to swap it for a th400 that i have to rebuild before then but if i dont what can happen?
and thank you for the info LETSDRG i think i will just swap cases once i pull it out and stick it on the shelf as a spare.
but i am hoping it will be ok until i get the th400 in.
