In an attempt to lower the car and give the suspension a little more travel, I am debating going with a coil over spring in the stock location. I know a lot of people do this so I was wondering what spring to go with. Currently I have f-body springs in it, which did lower the car some which is what I was looking for. The problem is that the moser 9" housing raised the rear of the car up and the fbody springs are a little stiff to get maximum weight transfer. I was playing with the suspension while the car was on the lift and noticed I wasn't getting very good travel. What are you guys using?
With no driver the car is 1410lbs on the rear.
What length and what weight?
