Board index » TECHNICAL » Suspension Technical
Post new topic Reply to topic  [ 15 posts ]
 Post Posted: Thu Mar 19, 2009 3:03 pm
MalibuRacing Authorized Advertiser
Just got done updating the website and all the information for the new parts. You can visit this link for ordering info or as always give us a call.
http://www.bmrfabrication.com/G-Body.htm
These new relocation brackets are laser cut and formed out of one piece of .180"(3/16) steel with another .180" plate TIG welded on the inside for an extra stout mounting surface. And the mounting holes (as with all our CABs) are on the same swing arc as the control arm so you will not need adjustable control arms to get these to fit right. Just make sure you double check your measurements before drilling or welding.
Depending on the ride height, these new relocation brackets offer 3 different mounting points to adjust the instant center on the vehicle. The holes are spaced at 2" 3" and 4" lower than the stock rear mounting point for the control arms.
Also these new brackets are a bolt in application but for the serious drag car we recommend welding them in.
Also here are the installation instructions for anyone interested.
http://www.bmrfabrication.com/INSTALL/C ... nstall.pdf
BMR Suspension Sales
http://www.bmrsuspension.com
813-986-9302
 Post Posted: Thu Mar 19, 2009 3:19 pm
:-k
1.51 60ft
10.89 @121.33
461 N/A pump gas
1.45 60ft
6.11 @115
9.74@140
461 with a Novi 2000 on E-85
Thanks to Ultimate Speed and Machine
 Post Posted: Tue Mar 24, 2009 12:01 am
Pro Moderator
Jay, have a part number for ones that are NOT powdercoated also. I have installed a few of your older brackets and grinding the powdercoating off to weld them in is a pain in the butt!
Kevin 78 Cutlass
KSR Performance & Fabrication
352-225-1210
http://www.InHisWakes.com http://www.TRZMotorsports.com
 Post Posted: Thu Mar 26, 2009 9:09 pm
Wow those look awesome! I'm intrigiued...
Have you ever considered doing something like those relocation brackets, but as a complete LCA mount for the end-user to install/weld on a Ford 9inch or 8.8 Rearend?
It certainly seems to be an improvement over the A&A Manufacturing mounts that seemingly do not have the advantage of having the mounting holes follow the same arc as the control arms.
If you ever manufactured something like that, I would certainly be one of the first on the phone to order a set!
 Post Posted: Fri Apr 03, 2009 2:51 pm
If you're going to order them just call us and tell us you want them un coated. We usually don't have a part number for the un coated until someone actually orders them.
I'll pass the interest along and see what we can do!
813-986-9302
 Post Posted: Thu Jul 04, 2013 1:32 pm
I am down for a set of LCA mounts for an 8.8, adjustable of course.
Speedway will not sell just the LCA mounts, and I don't need 9 inch UCA mounts or the caliper mounting brackets....
 Post Posted: Tue Jul 16, 2013 1:58 am
Hah hah haa
Found some for $28 a pair!!!!!!!!!!!!!!!
 Post Posted: Tue Jul 16, 2013 11:11 am
Links don't seem to work...
 Post Posted: Sat Sep 07, 2013 9:30 am
http://www.bmrsuspension.com/?page=prod ... &catid=106
|'87 Monte Carlo SS|'87 Turbo T|'02 Camaro B4C|'07 TrailBlazer SS|
 Post Posted: Sat Jan 11, 2014 1:14 pm
I am trying to decide if I need your relocation brackets. Right now my instant center is 42 inches and is above the anti squat line 2 inches. The way i figure it, if I lower it (2" it will change to 35.5" out and 4.75" up) (3" is 34" out and 5.5" up) (4" is 32.5" out and 6.5" up.)
I am figuring this with a tape measure and graph paper so I'm sure it is not perfect. Any info will help.
 Post Posted: Sat Jan 11, 2014 5:00 pm
I have these and recommend them if you don't want the car to squat
 Post Posted: Sat Feb 01, 2014 2:29 pm
I've decided to try the middle hole for this season and my pinion angle is -6, should I try and lift the car to seperate the suspension and measure that way? It has a limiter in the back so it'll only drop so far
 Post Posted: Mon Feb 03, 2014 5:20 pm
You need to get Adjustable Upper Control Arms - Part # UTCA007 with Poly Bushings or UTCA016 with Spherical Bearings
T.C.
813-986-9302
 Post Posted: Mon Feb 03, 2014 6:31 pm
Have some but they are umi with your brackets, is measuring it on the ground still the right way when its designed to seperate?
 Post Posted: Wed Mar 18, 2015 9:16 am
I bought these when I was completely stock suspension with a 9 inch, had some issues having them clearing the slicks (10 inch) and I didn't like how it drove down the strip. I didn't notice any 60 ft gains either but I'll have to try them again with all my new stuff perhaps.
