Board index » TECHNICAL » Suspension Technical
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post Posted: Tue Mar 31, 2009 4:45 pm
Any updates? I'm very interested in how this turns out, as I'm lookin for a rearend for the Elky. I've got two 8.8's laying in the shop, which would save me the headache of finding a 12 bolt.
 Post Posted: Wed Apr 01, 2009 3:27 am
MalibuRacing Authorized Advertiser
I'm still waiting on the prototypes. I'm planning on calling them today and see how they are coming with them.
Kevin
Kevin Slaby
http://www.BaselineSuspensions.com
Read: Launching a Drag Car
Read: Measuring Pinion Angle
Read: Setting Zero Suspension Preload
87 GN: 12.0 @ 111 60' 1.60
 Post Posted: Wed Apr 01, 2009 9:25 am
Any chance of getting weld on spring perches and shock mounts for this kit?
 Post Posted: Wed Apr 01, 2009 11:15 am
Right now I don't think I would have time to get them designed and out with the kit but maybe later if the need is there.
ks
Kevin Slaby
 Post Posted: Wed Apr 01, 2009 1:10 pm
Quick question are we going to be able to hook up the antiswaybars to these arms you are building or are we going to have to have something spcecial? :-k I would like to reuse my sway bar if possible. :D
 Post Posted: Wed Apr 01, 2009 3:34 pm
Good question. No sway bar mounts on these arms. My intention was for this kit to be use more for racing than street use b/c it will use rod ends to compensate for the different lateral angles. I am designing an UCA that will have a poly bushing on the chassis side tho for those street/strip applications.
Kevin
Update:
I test fitted the protoype parts tonight and they didn't fit as nice as I had hoped. They don't need much modifying but I have to talk to the company that made them and have them make changes.
Kevin Slaby
 Post Posted: Wed Apr 01, 2009 7:21 pm
any pics of the mock up????
Vodka Martini, shaken, not stirred.
 Post Posted: Wed Apr 01, 2009 7:36 pm
Not yet. I just tore it all apart...
ks
Kevin Slaby
 Post Posted: Sat Apr 18, 2009 12:38 am
Here is a sneak peak of what's been done so far and obvioulsy not all the parts are shown in the pictures (ie bushings, control arms, etc). These pics are only showing how the bucket fits in the frame. New control arm parts and bushings are still being designed and prototyped and I should have samples next week. Once everything is developed it will all be sent out for zinc plating.
This new design is being made as a complete Bolt-In to fit all G-Body cars and kits are being designed to fit a variety of rearends.
New Kits are being designed for:
Grand National 10-bolt rearend
G-body with A-body 12-bolt rearend
G-Body with Ford Mustang 8.8 rearend
G-body with Ford 9" rearend
Kevin
File comment: Trial Fit.
File comment: Torque Box Bucket
Kevin Slaby
 Post Posted: Sat Apr 18, 2009 6:00 am
I'm assuming that the pictures are of the passenger side upper. Will there be a sleeve over the bolt shown? Can (should?) the kit optionally be welded in?
Norm
1979 Malibu Classic (RIP)
2010 Subaru LGT (wife's DD, 6-speed manual)
2008 Mustang GT (Slightly unstock, 5-speed manual)
1995 Mazda 626 (bad winter weather driver and spare car, 5-speed manual, not stock either)
2001 Maxima SE (spare car, 5-speed manual, a little bit not stock, too)
 Post Posted: Sat Apr 18, 2009 6:32 am
Norm
Yes, the passenger side is shown. Yes, a spacer will be used where the bolt is and the bucket can be welded to the torque box but not needed. A hole will need to be drilled from the bottom of the torque box into the bucket so the bucket is bolted down real good so there will be two bolts holding the bucket to the frame.
ks
Kevin Slaby
 Post Posted: Sat Apr 18, 2009 9:32 am
that bracket is a good idea. i wanted to lower the front side of my uca but the increment was such that the new hole would overlap the original. I don't know which rear that is for, 8.8? but if you make that for the 8.5 gn rear i would suggest having the new holes start nearly in line with the original. maybe just offset 1/2 hole dia. at least that would work for me :)
 Post Posted: Sat Apr 18, 2009 10:50 am
Exactly! These are also being made now and each set of brackets will come with several mounting holes to fine tune the IC position depending on the cars ride height.
KS
Kevin Slaby
 Post Posted: Sat Apr 18, 2009 3:48 pm
When do think the control arm boxes will be ready?
UNDER CONSTRUCTION
 Post Posted: Sat Apr 18, 2009 4:09 pm
I'm hoping in about 3 weeks..
Kevin
Kevin Slaby
Users browsing this forum: No registered users and 3 guests
