Board index » TECHNICAL » Suspension Technical
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: Rear Suspension FAQ
 Post Posted: Sun Sep 18, 2011 2:14 pm
Barry 85 SS wrote:
Thanks, was looking for an alternative, as so many people on here say the Moroso springs are junk. My car is mostly street driven with an occasional trip to the strip.
www.santhuffshocks.com good springs ;)
Bob West- 1972 Chevelle Malibu
1.319-6.27@106.91-9.988@131+
 Post Posted: Thu Jan 30, 2014 4:06 pm
Hello guys I'm getting ready to install a spohn arb and wanted to know what rear springs to use I'm running a 275/60 15 dr I have moroso trick springs and was told not to use with an arb.. Any help would be appreciated..
Rodney Gilliam
 Post Posted: Wed Aug 26, 2015 3:56 am
I know this is an old thread but it's worth reviving
I see a lot of posts about expensive parts which are great parts to have but I don't see posts about economical parts and fabrications that work along with being cost effective
Bracing original LCAs/ UCAS
All G/A body's come with a small pinion snubber, make an adjustable model for 20.00 and 30 minutes.
Poly lift air bag on the right rear to help control the G/A body twist.
Adding MAXIMUM air pressure to the front tires. Having experienced the difference on the 4 wheel scales 10 psi added is equivalent to add 20 lbs to the rear.
This GN belongs to non other than Lawrence Conley owner of CPP, Master Engineer. Retired and enjoying life.
This car I spent a gracious amount of time on in my younger years. This car had Southside LCAs and stiffened uppers done in house, adjustable pinion snubber,air bag, frame rail mod to accept 15x10s best 60' back then was 1.43 and low 10 second runs "BLACK" was retired from drag racing.
'80 Malibu, 12-bolt, 4.10s, 5.3, 799 heads, baby cam, TRZ arms, C6 wheels, Ls1 brakes, 2" Belltech..more to come..
'93 TA, 5.7 Ls1 forged , T56, 8.8 w/3.73s, LG cam, 243 heads,NX
 Post Posted: Sun Sep 13, 2015 8:29 pm
what kind of spacing are you using for small pinion snubber how tight of a gap?
Dad you will be truely missed 09/22/2014
 Post Posted: Wed Sep 16, 2015 6:27 am
The new subbed is basically the same size as one that would be found on a set of Lakewood traction bars I cannot remember the moog part number but we drilled and tapped a 1x1", 3" section of square tubing and bolted it to the stock location. Once done the snubber is roughly 2.5" closer to the housing snout. We made them fully adjustable so that normal driving and suspension deflection during street driving does not break the rubber off of the stud.
