Board index » TECHNICAL » Suspension Technical
Post new topic Reply to topic  [ 104 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 Post Posted: Tue Oct 20, 2009 3:19 pm
Gitdowns wrote:
10secBu wrote:
5-door wrote:
You might find this hard to believe, but a Ford 9" is lighter than a 12-bolt. It's even lighter than a 10-bolt.
I'm not sure if I would buy that or not. If that were true, then why would some NHRA Super Stockers and Comp eliminator cars run a 12 bolt (I've seen dragsters with GM 12 bolts...I've even seen Mopar S/S cars with GM 12 bolts. I guess it could also be less parasitic loss due to the pinion to ring gear position. But a stock 9" with an iron center section, I'm pretty darn sure the 9" is heavier than a 12 bolt.
Not having weighed either side-by-side myself, I surely could be mistaken though.
They use 12 bolts because they use less hp. The loss in friction out weight the loss you would have because of the weight.
I know that and that's why I stated the examples given. But that is somewhat old technology.
The current tech setup for lowest drag in a rear differential is a Ford 9-9 1/2" center section manufactured by Dewco. Ultra low drag, ceramic bearings, all the tricks at a cost of around $5k for the assembled center section.
 Post Posted: Sat Nov 21, 2009 2:46 am
Stock a-arm with ball joint 8.4 lbs
Speedway upper front a-arm with Speedway ball joint 4.0 lbs
A-arm description: These 4130 chrome moly metric upper control arms are 40% stronger than standard control arms. They bolt to a stock mount and use the bolt-in style ball joints. Aluminum cross shaft.
Cost of the project from Speedwaymotors.com:
Qty SKU Description Price Total
2 91720045 GM UPPER BALL JOINT $14.99 $29.98
2 91031133-R UPPER METRIC A-ARM,ALUM/STL $47.99 $95.98
1 91016009 PRO-BLEND ANTI-SEIZE $6.99 $6.99
Sub Total: $132.95
Discounts: $0.00
Tax: $0.00
Shipping Total: $9.93
Total: $142.88
Will post pics and how-to article in the next few days if interested..
Dan Reisig, Kansas
79 Malibu, 10.5, 406, glide w/9"
http://www.2fatties.com
 Post Posted: Mon Jan 11, 2010 7:55 pm
how did those arms workout? are they stock length or do they changed anything?
http://www.westcoastgrudgeracer.com
------The SlaughterHouse------
 Post Posted: Mon Jan 25, 2010 8:01 pm
I wan to know about the deal on the arms as well, I am looking into getting a set of uppers and lowers for mine. I am going to rebuild the front end on it after the frame off.
"Currently under going frame off Restoration"
84 Monte Carlo SC 406 sbc
84 Monte Carlo LS 350 sbc SOLD
78 Monte Carlo 305 sbc SOLD
78 Monte Carlo Landua 350 sbc SOLD
84 Buick Regal 229 v6 SOLD
81 Malibu Classic 350 sbc SOLD
 Post Posted: Thu Feb 18, 2010 2:32 pm
just ordered these, ill let everyone know how they are!
 Post Posted: Tue Feb 23, 2010 7:59 am
got them yesterday and man they a light! good lookin piece
 Post Posted: Mon Mar 01, 2010 10:18 pm
Does anyone know off the top of their head how much a stock dash weigh? The only dash iv'e ever handled was one out of my dads '68 charger and it had to have weighed 30 lbs.
If you want it cheap and fast, it won't be good.
If you want it cheap and good, it won't be fast.
If you want it good and fast, it won't be cheap.
If people aren't talking about you, good or bad, your doing something wrong 8)
 Post Posted: Thu Mar 04, 2010 5:52 pm
I just had my dash out and they are pretty light. I would say not more than 10 lbs. I am getting my new dash this weekend and can weigh it and tell you this weekend if you want to know.
 Post Posted: Thu Mar 04, 2010 7:45 pm
Yea sure im interested, are you getting like a sheetmetal dash or a padded one?
 Post Posted: Fri Mar 12, 2010 8:00 am
the speedway arms worked out great! i wish they had lowers. only problem i had was when i took off the old ones i had to undo the motor mount cuz they were hitting my headers but other than it went smooth. great product.
 Post Posted: Sun Mar 14, 2010 1:19 pm
Flatblack, the dash is a factory dash and it weighs in at 5 pounds empty with the glove box and the cluster.
 Post Posted: Sun Mar 14, 2010 4:14 pm
ok, great to know thanks, Dekota/ Flatblack79
 Post Posted: Wed Mar 17, 2010 1:45 am
im might try them too!
 Post Posted: Mon Mar 29, 2010 2:56 pm
Anyone know where I can get plastic headlights(6054) for my 79 monte?
 Post Posted: Wed May 19, 2010 6:52 pm
Heres how mine turned out, steel bumpers and stock a-arms and a bbc.
1980 malibu 9.64@ 150.03mph on junkyard 5.3l with 78mm turbonetics so far
1993 GMC Jimmy 4wd twin turbo 6.0L Lq4 EFI
cron
