Stock Control Arm
richamer1
524
New Carlisle, Oh
Someone have a picture of stock upper control arm installed. Replaced my bushings and in the process got them mixed up between drivers and passengers side. I am sure at some point it will be obvious if it is correct or not. Just wanted to know before I started to reinstall. Thanks
TURNA
6,028
Socialist NY
Dont have a pic But I believe the upper and lower ball joint will not line up if you put the left upper on the right lower ...etc
It will probably create a steep angle, can't be sure... does this pic help?
DOUG213XRJ
4,671
West, MI
The Left and Right will interchange with each other. I installed mine wrong when I put my 79 frame back together after cleaning and paint. If you look at them you can tell its not right or left.
Doug
