Board index » TECHNICAL » Suspension Technical
Post new topic Reply to topic  [ 4 posts ]
 Post Posted: Thu Oct 20, 2016 7:38 pm
My car has been plagued with this problem since I bought in 06'. Since then I have replaced upper and lower control arms, all steering arm components and bushings, refurbished steering box, rid the circular padded bushing? on steering rod right before the box, new sway bar and bushings.
I'm stumped and don't know what's left. It is the same amount of play before I changed everything. It's a good amount maybe 10.30 - 1:30 amount of play
Any guidance would be appreciated. Shops here in S. Florida don't see. To be able to correct either
 Post Posted: Fri Oct 21, 2016 7:49 am
Have you played with the adjustemnt on the box? I did that on mine and it removed most of the play
-Greg...the Exhaust Guy.
I was into Malibus before they were 'cool'.
--'82 alldoor 267 Turbo/200r4/3.73LSD 'malibu5' 'worlds fastest 267 lol'
Undergoing Toyota aluminum 4L V8 swap
--'84 Bonneville 311/200r4/4.11 8.5...soon to be drag sleeper
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
 Post Posted: Mon Oct 24, 2016 11:42 am
With everything else listed that you've completed, I'd say that would be your best bet. There are two different adjustments to make. I believe there is a user guide on the internet on one of the gbody centered forums (not sure if I can link to them). montecarloss or gbodyforum for sure has a thread about them. The first one seems to just firm up the steering, the second one removes slop.
 Post Posted: Thu Nov 10, 2016 10:11 am
You need a second person. Get someone to wiggle the wheel while you watch, starting from the steering shaft down. This method always works for finding slop. Just look to see where there is a disparity in what moves.
-Martin
1987 Cutlass- 403 Olds BB E heads, 10:1, t56, 4.10's.
1972 Plymouth Satellite Wagon- AACA HPOF preservation car, one owner, all original
2001 Dodge Ram ext cab long bed- Cummins 6 speed
