Board index » TECHNICAL » Suspension Technical
Post new topic Reply to topic  [ 1 post ]
 Post Posted: Wed Aug 10, 2016 10:01 pm
Just an FYI.
I bought a pair of Speedway Motors front upper a-arms. These are chromoly tubing with aluminum cross shafts. Part number for both right and left side a-arms are 91034393-R.
http://www.speedwaymotors.com/IMCA-Spec ... ,2120.html
Speedway motors a-arms have no travel stops built in like the stock a-arms, but you loose about 4.5 lbs per side (roughly 9 lbs total) with these a-arms. The weight comparison included both a-arms having ball joints already installed.
8.7 lb - Stock A-arm weight
4.2 lb - Speedway Motors A-arm part# 91034393-R weight
These cross shafts have zerk fitting to lubricate the solid bushings.
There is also a little more clearance above cross shaft versus the stock control arms which may help in header or down pipe clearance.
Here is a link with another person using them on an S10.
http://www.s10forum.com/forum/f307/tubu ... ms-423939/
David Schultz
MalibuDave
www.manualbrakes.com
https://www.facebook.com/manualbrakescom-576443512373024/
