Board index » TECHNICAL » Suspension Technical
Post new topic Reply to topic  [ 9 posts ]
 Post subject: Bump steer help
 Post Posted: Thu Jul 14, 2016 11:05 am
Hello, long time no see. I need some info for my front end. Have a 78 wagon. Plan on building an aluminum headed 383. Air, heat, cruise stripped from car. I have polygraphite bushing in the arms and stock replacement tie rods and ball joints. I have a set of extreme blazer spindles I want to use and plan on ordering moog 5606 springs for the front. Anything I need to change to kill bump steer before I put all this together?
1978 chevy malibu wagon
383 in progress
89 s10-beat the ever livin #### out of truck
2013 crane carrier front loader
theres a reason why malibus rule the world
 Post subject: Re: Bump steer help
 Post Posted: Thu Jul 14, 2016 4:26 pm
If you're drag racing the car, don't worry about bump steer. There hardly is any from the factory. Autocrossing, that's another issue.
1978 Malibu Coupe SBC TH350
1979 Malibu Coupe LQ9 TCI 6X
 Post Posted: Thu Jul 14, 2016 9:11 pm
Call Savitske. I never thought these old ######## can turn so well. Car is much better then factory.
-Greg...the Exhaust Guy.
I was into Malibus before they were 'cool'.
--'82 alldoor 267 Turbo/200r4/3.73LSD 'malibu5' 'worlds fastest 267 lol'
Undergoing Toyota aluminum 4L V8 swap
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
 Post Posted: Tue Jul 19, 2016 9:01 am
MalibuRacing Authorized Advertiser
Bump Steer can get complicated when you get into specifics and measuring.
In a "nutshell" you want your tie rods as parallel to the ground as you can get them. Bump Steer is improper length or angle of your suspension and steering linkages due mostly in part from changing the ride height or tire size.
Craig
UMI Technical Support
UMI Performance, Inc.
support@umiperformance.com
http://www.umiperformance.com
814.343.6315 x102
 Post Posted: Sat Aug 06, 2016 7:12 am
Use the longer upper ball joints to help your camber curve too. Those help handling immensely.
'78 bu, 350/310 hp, M-21. Now with a GN 3.42 rear and Detroit Tru-Trac, Xtreme rims, grey bucket seat Monte interior
 Post Posted: Fri Sep 09, 2016 1:35 am
The other issue I'm having is the tie rod mounts on the spindle are longer with the blazer setup, my tie rods stick out further. Should I run the blazer pitman and idler arms and see of that helps? Car will be driven
383 in progress
 Post Posted: Sat Oct 01, 2016 9:09 pm
Craig
Isn't it more important to have the tie rods as parallel as possible to the centerline of the lower A arm pivot & ball joint?
 Post Posted: Wed Oct 12, 2016 9:42 am
Craig
Yes Tommy, it is. The misinformation just flows through these forums like floodwater.
TRZ MOTORSPORTS
Manufacturer of Performance Suspension Components
Dealers for the following: AFCO, Strange, QA1, Menscer Motorsports, Flaming River, Double AA Performance, Baer Brakes, Optic Armor etc...
Friend us on Facebook (TRZ Motorsports)
http://www.trzmotorsports.com
407-933-7385
 Post Posted: Fri Oct 14, 2016 8:58 am
Oops, sorry. It's easier to explain with a diagram.
http://www.longacreracing.com/technical ... o%20Basics
Really the only way to know if you have zero bump is to use a gauge. Or if you have more time and skill than $ (which is most of us), you can take the front springs out and measure toe at various ride heights.
Then, you can use a bump steer kit to change the angle of the tie rod to minimize bump steer (aka toe change during travel).
This can help a drag car go faster because it's not going pigeon toed as it's going down the track.
Hope that helps.
Craig
814.343.6315 x102
