Mini Tub Elcamino G body - Need Feedback
rwolf15241
47
Pittsburgh, PA 15241
I'm thinking about doing a Mini Tub and frame notch. I will be removing the frame soon, after I decide on wheels. Planning on 18x10-18x12 rear wheels and 18x8.5 in the front. I have a plasma cutter & mig need to practice using it!! LOL. The rears inside wheels wells would need replaced, be cause t is in full view!!
What do you guys think??
Bar50
1,870
Tulsa, OK
Nice wheel tubs will look awesome. Keep us updated. If you need some ideas look around over on yellowbullet.com search for Malibu or TRZ or frame notch for plenty of build pics.
bustedknuckle
959
St. Louis-Missouri
Mini tub and frame notch is cakework on an elcamino. nothing in your way. heres mine
Oh BTW 18x10 will work with a frame notch and minitub but not a 18x12 if you plan on tucking the tire.
Or you can do a FULLTUB like this. :lol:
rwolf15241
47
Do you have more pics??? I was going to tub it to the inner wall. looking at 18x10.5 wheels and 18x9 in the front!!!
1982 SS
382
Clearfield, Utah
Yes, more pics on that notch! I notched mine and used a wheel well tub kit from Jegs and it doesn't look too out of place, but I'm far from finished with the body work. I went all the way to the inner skin too.
I run 29x11.5" slicks on 10" wide 15" diameter rims and they rub if i take a corner very quickly at all. A 10.5 or 11 would make things easier on the rubbing.
406Elcamino
556
bump*
im contemplating the same project right now i have to cage my elcamino this winter and while im in there i might as well make room for the full tub
i already did the frame notch but i want to go to the inner skin now
406Elcamino
556
Hey i wasnt going to start a thread but im looking for any and all pictures and info on cages for el caminos
rwolf15241
47
I'm looking at Jegs 4 point with pro touring low side bars.. I will run the rear bars in the storage area. I want to make it a bolt in cage!!
