G Body Moly roll cage kits
92Camaro
30
Brownstown, Mich
Any body out their offer a through the dash G Body all moly roll cage kit that will pass certification to 7:50 e.t. I have looked at the S & W kit ,etc. What else is out their and prices ?
Thanks for looking,
Ron 92Camaro
Brownstown, Mi
10secBu
4,284
Westminster, MD
I would suggest finding someone to custom build one as you'll get a better fit when done. 7.50 cert means a 25.5 SFI cage, not an easy job.
Through the dash is not something you'll normally find for prebent kits for the g-body.
Don't know if it's an issue for you, but moly cages must be tig welded...
brunz21
152
chicago, IL
ive never seen a kit like that, ur looking at a custom bent cage. why do you want to go thru the dash? why not right in front of it on either end where it curves in?
1Gary
260
Roch,NY
Moly and rolled steel being dissimilar metals can be problematic,so if your adding on to a existing roll bar that is rolled steel,get it tig done by a pro shop.
1Gary
260
Roch,NY
1Gary said:
Moly and rolled steel being dissimilar metals can be problematic,so if your adding on to a existing roll bar that is rolled steel,get it tig done by a pro shop and have them gusset wherever possible.
