Installing tubular upper/lower control arms and QA1 coilover
Jayz79
283
algonquin,IL
Hello, I purchased the B-Body spindles from GM parts direct, and A-arms from Spohn. Im not sure if anybody has this exact setup.
I installed the drivers side components, It doesn't look correct.
Does the lower end of the spring look wrong in the picture? Im not sure if the spindles look like the B-Body ones.
I don't have the upper shims installed so the upper arm is a little loose too. The upper ball joint looks cocked , the seal is coming apart also. It looks too low, etc. My guess is that since there isn't any weight on the car, it looks this way. Any advice? Thanks.
1980PontiacWagon
686
Northern Virginia
Re: Installing tubular upper/lower control arms and QA1 coil
It should straighten out when you put some wight on the front end
bugm
79
bowling green ky
mine look like that too but only on pass. side with weight on car beendriving it for 2 years how long do I have to wait and how many sets of tires
malicad
1,383
South Milwaukee, WI
Are those upper arms designed to function with the B body spindles?
