s-10 steering box/pitman arm issues
madmaxx57
237
DURAND IL
ok i have the s-10 box..my stock pitman arm wont fit the box?..it appears my box's shaft is 1-3/16 and my p-arm is 1-1/16..the car is a 78 mailbu..anyone else have this issue? my search tells me my pitman arm should fit????..help..thanks
bowtie81
5,008
sarnia, ontario canada
Use the pitman arm that came with the S10, thats what i did and had no troubles.
madmaxx57
237
DURAND IL
ok kool, just wanted to make sure..i dont have one in my hand to compare to. so i will try to hunt one down..thanks!
madmaxx57
237
DURAND IL
what year???..looking on ebay all those show a stud on the non-box end..my malibu arm has female ends..or holes..no studs..so maybe this is a no-go??
madmaxx57
237
DURAND IL
i can get a pic tomm. ebay shows a big and small pitman arm for malibu??..i was told this is was an ez swap..lol..never is...
bowtie81
5,008
Send me the links for ebay
I had mine done in 20 min, once you get the proper arm it will be a sinch
madmaxx57
237
DURAND IL
for the most part it was ok..just this arm issue..the item number is 250389433364..this what my current arm looks like
madmaxx57
237
DURAND IL
anyone have some hard dimesions on the steering box shaft ?..i'm thinking this box is wrong..what years of s-10's have the correct pitman arm???
madmaxx57
237
DURAND IL
ok i can only assume the dim for the spline on the pitman arm is taken from the large part of the spline..so the s-10 box has 1-1/4 and my org. p.s. box looks to be 1-1/8..what yr s-10 pitman will work?..i bought the box from someone so i dont have the donor vehicle..anyone??
