Frame Bracing and notching
Trick Chassis
62
Brodhead, Wi
www.trickchassis.com
Some pictures of Mike's car were finishing up at the shop. Did a frame box, rear frame notch and some coilovers. Also a few other things...
Check it out
malicad
1,383
South Milwaukee, WI
Nice work! Any idea as to how much weight was added to the frame with all the boxing and bracing? Looks like maybe 40 pounds or so of extra tubing, depending on wall thickness. That going to be a drag car, or touring?
Trick Chassis
62
Brodhead, Wi
DamageInc85 said:
Nice work!Is that basically a 25.xx type chassis without a cage?Whats something like that cost roughly?
Depends on many options. Just the frame box and bars from the LCA's to the front with trans crossmsmber your starting at $1500
The frame box added the most. I am in the process of having some laser cut with some nice light weight design.
This is a street car. He wanted to do everything but a cage to try and make it stiff as possible. We did our best to triangulate the bars and add dimension.
