Board index » TECHNICAL » Alcohol/Ethanol
Post new topic Reply to topic  [ 3 posts ]
 Post Posted: Tue Jan 29, 2013 8:25 am
Hey guys,i'm currently building a engine and i thought it would be interesting to get some guesses on the hp and torque it will make.The specs are below,lets here you guesses
331 sbc,4.030 bore 3.25 Stroke
12.5:1 compression
AFR 220 fully cnc heads
Brodix HV1002 Single Plane 4500 intake with custom 4150 adapter
950 Holley HP alky carb
Soild Roller Cam .630 lift,in/exh,301┬░/309┬░duration,3800-7600
Jesel Belt Drive
Canton Drag power Pan
Running it on Methanol
So let here some numbers Guys
1979 Malibu wagon
377 Stroker,AFR 220 full CNC heads,Lunati Soild Roller cam
TH350w tbrake,J&W Ultra Bell,Hughes 4000 Stall Converter
9" Ford w/disc brakes,Spool ,4.86 gears ,30x9 slicks
3300 lbs
Gutted for drag racing.14 point cadge.
All steel car,No fiberglass
10.76@125Mph 1/4 Mile
1.50 60 ft
 Post Posted: Sat Feb 02, 2013 7:30 pm
Thats an interesting combo and when you do run or dyno it I would like to know the results. I'm guessing it will be weak on the bottom and MPH on the top - should like RPM.
i'm guessing about 525.
 Post Posted: Sat Feb 02, 2013 8:18 pm
looks like you'll need a 5500 stall and 5.13 gears. A light car. I'm reall interested to know as well. I'm not real knowlegeable on what the methanol will do for you. Is that duration at .050?
brian
What does it profit a man if he gains the whole world and loses is own soul?
http://therocketshop.blogspot.com/
