Board index » TECHNICAL » Alcohol/Ethanol
Post new topic Reply to topic  [ 3 posts ]
 Post Posted: Wed Aug 17, 2011 8:13 am
Does anyone know of any bad side effects of using e85???
 Post Posted: Wed Aug 17, 2011 9:50 am
Just the availability. I have drove mine all year on it. Not had any corrosion issues, because I drive it regularly, the car runs cool and makes great power. I love the stuff, much cheaper than race fuel or 93 octane for that matter. Of course your car has to be up to the task so if you have to upgrade a bunch of things that might be a slight drawback.
83 Monte Carlo SS, bbc, PTC converter, 10" tires
1.41 9.47 145.6 shakin it down
82 Cutlass 10.17/133 blow thru
http://www.ultimatespeedandmachine.com/
 Post Posted: Wed Aug 17, 2011 7:01 pm
my car used to run hot, put the blower on, changed to E-85 and put an electric water pump on. Now even in the South Carolina heat it run like a champ. only side effect is more smoke from the rear tires....
1.51 60ft
10.89 @121.33
461 N/A pump gas
1.45 60ft
6.11 @115
9.74@140
461 with a Novi 2000 on E-85
Thanks to Ultimate Speed and Machine
cron
