Board index » TECHNICAL » Interior Tech
Post new topic Reply to topic  [ 6 posts ]
 Post Posted: Tue Feb 20, 2018 9:58 pm
I have two 78 Buick Regal steering tilt columns. One has something going on with the actuator and the other the tilt is loose. How do you get the turn signal lever out? The lever is the light dimmer switch and cruise control. I removed the bar that connects to the signal switch. Stil can't see a way to remove the lever.
 Post Posted: Wed Feb 21, 2018 3:56 am
Twist and pull
1980 Malibu BBC T-56 9"
1986 Oldsmobile Cutlass.
 Post Posted: Wed Feb 21, 2018 6:41 am
Thanks, I'll give that a try.
 Post Posted: Wed Feb 21, 2018 11:51 am
I tried twisting both right and left, it wouldn't let go.
 Post Posted: Wed Feb 21, 2018 8:27 pm
If it has the wiper controls on that lever too you don't have to remove it to tighten the tilt screws. You remove the steering wheel,lock plate and cancel cam, there is a screw holding a small lever on the turn switch that is actuated by the turn lever. Just FYI if you have never tightened the screws for a lose tilt column before you are in for pita. Ive probably fixed a hundred over the years, with all the right tools, it still takes me about an hour to fix one right.
80 Malibu. 496 pump gas.
10.09@132 N/A
6.33@109 n/a 1.38 60ft. With South Side bars!
9.75@135 100 shot.
A stupid question is better than a stupid mistake!
 Post Posted: Wed Feb 21, 2018 8:43 pm
As far as I know there isn't a wiper switch on it. I have a second column that looks the same but has a problem with start actuator. All the screws are removed, but haven't figured out how to remove the turn signal lever. I haven't ever adjusted tilt either. I might need a lot of help to get it right. Thanks for your help.
