Have any of you guys fixed the channel that the upper panel goes into ? Im sure you all know the problem since it seems to happen easily. The channel pulls away from the little melted over posts that hold it together. I picked up a couple of door panels at a yard today and the better of the two needs to have the channel repaired. I was thinking about cleaning it real well and using an epoxy. There isnt enough plastic there to try to melt over. Also, what the heck takes off the glue from the old carpet ? Im using a heat gun to get the carpet off but theres still quite a bit of glue left.
