gauge cluster help
elcaminoss84
336
Oklahoma
since im swapping from a sweep malibu cluster to a buick regal cluster. im needing some help finding a picture of what each wire goes to that plugs to the back of malibu sweep cluster. also i need a picture of what each wire goes to that plugs to the back of a 84 regal instrument cluster. so i just have to relocate the wire in the plug to run my regal cluster instead of swapping interior wiring harness from a malibu to regal.
Take a gander at the back of your Regal cluster, the gauges will share a +12v trace, and the illumination bulbs will share their ground trace with the gauges. The remaining connection for each gauge will be the lead to the sending unit, etc. Then do the same for the warning lights, blinkers, high beam, etc. I did with my Grand Prix cluster and everything works properly.
