i can get a rally gauge cluster but it doesnt have a rmp gauge it has a blank gauge and the temp volt and oil are just lights can i pull those out and put in real gauges???
If it has dummy lights where the volt/temp/oil gauges would be, then no. You need a different cluster housing and printed circuit board. There are also some changes in the harness plug you need to make.
