Turn signal bulb in dash replacement
Brown_Gbody
3,078
Milwaukee, WI
4 or 6 screws to remove the cluster from the dash, and you can access the circuit board that holds all the lamps. Really an easy operation.
Seems like there was a post on here about replacing those lamps...?
tiedyemike8
658
Naperville, IL
If you're skinny and flexible you might be able to reach up under the dash to pull the bulb out, that's the fastest way.
I think Mike's Montes sells brighter dash lights.
t5montecarlo said:
I suggest that 194 is adequate for turn signal bulbs. 168s will be too bright since they are directly behind the lens.
Good point. I wasn't thinking about turn signals. I was remembering gauge lighting.
chevynut50
27
Newport News, Virginia
Finally got around to replacing bulb. All turn signals work on the outside and the passenger side dash light blinks but the drivers side is still not working. Any thoughts anyone.
4,654
31
perhaps not making good contact between the socket and the printed circuit. You will need to remove the entire housing or try and get at it from underneath (difficult). While it is out, clean all contacts.
