Vintage Air heat units
malicad
1,383
South Milwaukee, WI
Any chance you could share the part number with us? I went on their site, and there are a bunch to choose from. Great job with the install by the way \:D/
malicad
1,383
South Milwaukee, WI
INTHE10s said:
If its the 1 from the link he posted then 506101
That link doesn't work for me for some reason...just opens up a blank pdf file....but thank you.
Embryo
25
54165-WI
That number is correct. Whatever you do make sure to order a Gen 2 unit as they have an electric servo for the coolant flow instead of a vacuum operated one.
I installed my defrost vents in the dash last night and I am trial fitting the ducting tonight before final spraying the new dash in SEM. I will post up a few pictures of everything before I button the everything up.
shvrolay
