Board index » TECHNICAL » EFI Tech
Post new topic Reply to topic  [ 3 posts ]
 Post subject: ls1 m6 swap..
 Post Posted: Mon Jun 14, 2010 9:04 am
i am currently wanting to install a ls1 in my 81 elcamino, i am running it efi and i was wanting to know what gas tank and sending unit i would need? return or returnless? and from what year gas tank would fit my 81?
BE-GIN-NING, The point in time or space at which something starts.
 Post subject: Re: ls1 m6 swap..
 Post Posted: Mon Jun 14, 2010 6:58 pm
You'd need a stock El-Camino FI gas tank. They only came in the later year elco's 84- newer I think, with a 4.3L V6 TBI motor. You also need the sending unit assembly from the same. BUT you'll have to change the pump itself out to a higher pressure and volume one. Thats if you want to stay in tank, if you want to go external, there are dozens of choices. For the intank you run a Corvette Fuel filter/pressure regulator assembly, pretty cheap, I think around $55 or so. Ck out the LSX swap forum on here for more info and idea's. HTH
'78 bu, 350/380hp, M-21. Now with a GN 3.42 rear and Detroit Tru-Trac, 18x9.5" wheels on all four corners with 275/35/18's, grey bucket seat Monte interior
 Post Posted: Tue Jun 15, 2010 9:20 am
thanks! i will be searching for one asap.
cron
