Board index » TECHNICAL » EFI Tech
Post new topic Reply to topic  [ 6 posts ]
 Post subject: Return line?
 Post Posted: Wed Mar 10, 2010 11:00 pm
Long story short, the return line is causing my LS swap to run rich. Pretty sure its just too small at 5/16" Heres my question, should I mod the stock unit to make the line larger, or weld a bung in the tank and run the AN stuff to it?
Quote:
back it outside and do a burnout till the axle,tire,brake line and brakes come off the passenger side of the car. get out, throw your arms up in the air and start chanting "im awesome".
 Post subject: Re: Return line?
 Post Posted: Thu Mar 25, 2010 5:25 pm
Can't you just adjust the program to make the injector size larger?
That would match the added pressure causing the injectors to be bigger than rated and actually be better for tuning.
If you have to run a bigger line and the tank is coming out anyway, do the best way so you won't have issues again.
IMO Bung with AN would give the best sizing choice.
New 406, 10.5 CR, 236/242 HR, Stealth Ram, 30#, 52mm, 3800 triple disk L/U, built 700R4, 3" full w/X
Old info...
http://www.wideopenwest.com/~JohnandRuth/MonteWeb/photo.htm
Doubled post..
 Post Posted: Thu Mar 25, 2010 10:27 pm
Turns out it was a pinhole at the dump into the tank, and 5/16 is big enough.
And I wouldnt think you could adjust the injectors for 130 psi. Could you?
 Post Posted: Sat Apr 03, 2010 4:57 am
I had a very simular problem when I converted to TPI in my car. I used my old main fuel line (5/16" on V6 car) as the return. The main was plugged beyond belief. How the V6 ever even ran was a wonder. I had over 100 psi fuel pressure and it would not come down. Replaced the return with new line...pressure returned to the normal 45 psi.
Doug Gulley
86 Cutlass, 383 needing a rebuild, AFR 190, Accel SuperRam, 30# SVO inj, 58mm tb, AFPR, aftermarket T56, C5 brakes *under construction*
Planned upgrades*** 17x8.5" Rondell #58's, 275/40 & 245/45 tires, LS1 rear discs, rear suspension upgrades, etc...etc...
I can explain it to you, but, I can't understand it for you
 Post Posted: Sat Apr 03, 2010 11:21 am
Glad you found the issue. On an EFI set-up a small return can be used due to the much higher base pressure (vs carb).
CDR Performance
The Custom Engine Shop
Official Sponsor of the first Annual
YellowBullet.com Nationals
