Board index » TECHNICAL » EFI Tech
 Post Posted: Thu Jan 26, 2017 2:13 pm
I am switching over to TBI and installed the new tank plus sending unit. Sending unit is below. I am going to run the braided flex hose tank to engine. How is everyone attaching the hose to the sending unit. I found some fuel injection hose clamps, would those be strong enough or is there a better way and cost effective?
https://www.amazon.com/Spectra-Premium- ... B001DBTUX8
 Post Posted: Thu Jan 26, 2017 3:00 pm
AN fittings would be best, and Fragola makes compression-style adapters that could go on that sending unit after you cut the hose barb off. That adapter makes a "cut off steel tube" basically have a male AN fitting. Then, just go ahead and use the corresponding female AN fitting on the end of the hose. I'm in the process of basically doing the exact same thing with my wagon. You could also just use fuel injection-style hose clamps, but IMO, putting them over steel braided fuel line probably won't work that great, especially with the higher pressures of efi.
Here you go..
http://fragolaperformancesystems.com/ha ... -fittings/
1978 Malibu Coupe SBC TH350
1979 Malibu Coupe LQ9 TCI 6X
 Post Posted: Thu Jan 26, 2017 5:23 pm
thank you
 Post Posted: Thu Jan 26, 2017 9:44 pm
No problem :)
Users browsing this forum: Exabot [Bot] and 1 guest
