Hello all,
My malibu with the TBI 350 is in need of a new fuel pump. Ive decided that an electric external in-line pump would probably be best going forward. Ive narrowed the choices down to 3 and was hoping someone has experience with any or all of these.
The 3 ive located are Holley's 12-927 (150-160 bucks), the Walbro GSL392 (112 bucks) and pump from The Racers Edge TRE-200 (90-100 bucks). All 3 will support TBI pressures and the Holley seems to cap at 15 psi, not sure if thats a pro or con but with fuel pressure being key to feeding a performance TBI engine I figure a higher cap would be better (which the other 2 provide and are cheaper)? Am I wrong in my assumptions or would the Racers Edge or Walbro pump be a better bang for my buck?
Thanks in advance. After further review the TRE-343 is an in-tank replacement, too bad, for 70 bucks I was considering pulling the trigger. The inline fuel pump from TRE is TRE-200 and its only about 12-15 bucks cheaper than Walbro. However, the TRE does come with a 1 year warranty whereas the walbro does not.
Ken
Ken
