New member here, tons of questions.
1fine 79
New Member
Oct 15, 2012
Hi guys/ gals. I've lurked here for about as long as the site has been around. Just joined recently. I'm working on converting my older 2pc rear main seal 355 and t56 combo over to an 89 Tpi 350 system. So far I've lined up the fuel system (monte tank and hi psi pump) heads, (procomp aluminum 200cc runners with 58 cc chambers) tuning, harness, (fuelinjectionconnection.com) and all that. I want to run maybe 28 lb injectors. Please give pos v neg of that. Also, I'm having issues with cam choice. Currently the cam is the old lt1 flat tappet grind from the 70s only not solid. I want a good cam to work with the ecu and since it's a maf system I have some wiggle room. Thanks. My car can be found with a google search of 79 malibus. Red with black ion 17s and an ugly black Pontiac aztec in the picture background. Lol. Thanks all :D
