Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
 Post subject: Rate my bbc engine combo
 Post Posted: Wed Feb 10, 2010 4:15 pm
468ci bbc
1050 holley dominator carb
team g intake with 1inch spacer
proform 1.7 rockers
dart iron eagle 345 119chamber 2.300/1880 valves
doug herbert solid roller cam .703/.708 lift 305/314 dur 108 ls
doug herbert solid roller lifters
ross 36cc dome pistons on 6.385 " h-beam rods
stock crank
trans th400/5000 stall
4.56 gears
mt 28x10.5w slicks
hope to go 6.90 in the 1/8 on motor in a gutted malibu wagon :D
1979 Malibu
406 6 inch rods kb .150 dome pistons
hurricane intake 750 dp
doug herbert solid cam 290/300 528/552
chevy 461 heads
NOS Cheater system
Th350, 3500 converter
4.56 gear ratio
28 inch M/T ET Streets
 Post Posted: Wed Feb 10, 2010 6:14 pm
i hope you have aftermarkit pistons and not stock replacements, that big of a lift it will hit pistons.
http://www.youtube.com/watch?v=umfd23bxM30
 Post Posted: Wed Feb 10, 2010 7:55 pm
they are ross part#82012
1979 Malibu
chevy 461 heads
NOS Cheater system
4.56 gear ratio
 Post Posted: Wed Feb 10, 2010 9:17 pm
If it doesn't go 6.30's there's something wrong with it. :D Although, in my opinion, the heads are too big. Still should go better than 6.90's. Lee
 Post Posted: Wed Feb 10, 2010 9:36 pm
so it would be faster with the dart 308 int runner 119 chamber 2.250/1.880 valves
1979 Malibu
chevy 461 heads
NOS Cheater system
4.56 gear ratio
 Post Posted: Wed Feb 10, 2010 10:40 pm
In my opinion, yes. Or even a set of Dart 320's maybe. Mine has 290cc heads with 2.19 1.88 valves, 850 carb, bigger cam (lift), less compression, and has been 6.43 (1/8th) and 10.17 (1/4). Lee
 Post Posted: Wed Feb 10, 2010 11:41 pm
I would consider going to a better brand of rocker like a crane,comp or scorpion ive seen those proform fail on less cam and spring pressure before.Just my .02
81 malibu
355
unported vortec heads shaved to 56 cc
solid flat tappet crane cam
stock rods and crank w arp
best of 12.511 na/11.519 w 125 shot
Hopefully gettin a 6.0 by summer!!
 Post Posted: Thu Feb 11, 2010 9:10 am
Heads are too big. I ran a set of Dart 325's on my 468 that had a little more cam in it and it didn't pick up much over the 781's. More I think because of weight. I always thought my combo would have been better suited by some bmf 310's or afr 305/315's.
83 Monte Carlo SS, bbc, PTC converter, 10" tires
1.41 9.47 145.6 shakin it down
82 Cutlass 10.44/130 pump gas nitrous
6.62/112 e85 blower spinning
http://www.ultimatespeedandmachine.com/
 Post Posted: Thu Feb 11, 2010 9:31 am
i also have a comp solid roller cam .748/.710 lift 311/315 dur 110 lc 5000-7500 rpm would it help if i ran this cam
1979 Malibu
chevy 461 heads
NOS Cheater system
4.56 gear ratio
 Post Posted: Thu Feb 11, 2010 10:05 am
Heads may be too big but they may kill enough bottom end to hook the thing. You've got a small tire, a lot of gear, and a 2.48 first gear ratio. Start saving for a glide! The engine combo sounds pretty stout. Like others said--if it hooks you should be 6.40 or better.
Mike Allred
83 El Camino footbraker
 Post Posted: Thu Feb 11, 2010 11:17 am
thanks guys for all the info/help
1979 Malibu
chevy 461 heads
NOS Cheater system
4.56 gear ratio
 Post Posted: Thu Feb 11, 2010 12:50 pm
What's the duration @ .050 on both cams?
Also, what does the static compression work out to? My guess is around 11 or 11.5 to 1 at best.
I also agree the 345 runner heads are way too big, that coupled with low-ish compression and it's not gonna perform to it's potential, but should go 6.90's.
My old BMF 310 headed 461 bbc went as quick as 9.48 @ 141 and 5.95 in the 1/8 naturally aspirated at 3400 lbs.
Performance comes down to a well matched combination and your proposed deal is lacking in matched components.
 Post Posted: Thu Feb 11, 2010 1:28 pm
compression 11 to 1
dougherbert 270/279 dur @.050
comp 274/284 dur @.050
1979 Malibu
chevy 461 heads
NOS Cheater system
4.56 gear ratio
 Post Posted: Thu Feb 11, 2010 10:41 pm
will it help if i add a 200 shot of nos to this combo to make up for the heads being to big :D
1979 Malibu
chevy 461 heads
NOS Cheater system
4.56 gear ratio
 Post Posted: Tue Feb 16, 2010 12:24 pm
will the nitrous help me [-o<
1979 Malibu
chevy 461 heads
NOS Cheater system
4.56 gear ratio
