BBC OEM crank, rods HP capcity/build... sugestions please
malibu795
1,496
4
spgfd ohio
getting ready to rebuild my BBC
goals reliable DD rpm limit under 6,000 and .9-1.1:1 hp ratio ~9-9.5:1 c/r
crank is already .020 under going .030 unders
bore is .040 over going to .060 wiht KB202 pistons
its going to cost ~150.00 to under cut the crank and nother 100 or so to re-condision the rods.. should i junk it and pick up a cast steel scat/eagle crank? for ~250
i have been told then stock crank and rods have been ran up-wards of 700hp on claimer motor setups... yes/no?
still have stock O-port head that will be taken out to 2.19/1.88 valvs and ported from 2.06/1.75
block is getting bored and posibly deck.( think its been decked before) might line bore it as well
Damon
1,655
Philly Area
700HP on a stock cast crank sounds kinda nuts to me. Hopefully it's true since that's about what I'll be making when the bottle goes on my 454!
For what you're doing a stock cast crank is fine. Nothing wrong with KB Hypers as long as you're not boosting or hitting it with spray. I've beat the crap outta MANY sets of KBs and never killed a set until I started playing with the roots blower combo in my 78 Malibu. It took a while to learn how to tune a combo like that and I killed a few sets due to my own stupidity (tuning right into detonation, which they can't take for very long in a blown/nitroused application). On a modest N/A engine you'll probably never break them if you mind KBs special specs for top ring gap.
TNTS79
1,252
Illiniois
700 hp is a sure way to send that cast crank through the pan in about 5 pieces! Get a new crank, have the bottom end balanced, especially with big blocks. A 10:1 bbc with a decent set of heads is easily capable of upwards of 500 ft. lbs of grunt and around 400 hp if the heads and cam are matched up properly. More than enough for a DD!!
Simple recipie for a daily driven street deal... I have this motor in my 70 camaro, Dyno'd right at 500 hp and 525 ftlbs... runs 11.80's in a 3500# 70 camaro.
std bore 454 (i had a marine virgin block laying around) stock marine forged pistons with a little pop up like .125 cast crank, stock style dimple rods, good rings.. Heads are a mild ported set of 781 casting numbers, untouched performer RPM air gap, 850 holley and off the shelf extreme energy 284 cam and lifters, hardened pushrods and roller rockers... 2" primary headers.. runs on cat pee 87 octane, sounds lumpy and cool and you can drive it anywhere...
I see you have a t56 car listed in your sig.. that would be a TON of fun, 525 ftlbs and you wont even need to shift down :lol:
malibu795
1,496
4
spgfd ohio
~400-450 hp is the goal
no plans on blower/turbo or N20
currently have a 208/218 @.050" .475/.500 cam in the motor...
~325hp/475lb roughly...
moves pretty well with 2.41:1 rear gears and 26" dia tires... all things considers..
BTW running 4200lb and ~75mph got ~18mpg cruising 1800rpm...
the 700hp statement came from Speed-o-motive.. said the did that in their "claimer" motors..
Wellll... GM used forged cranks in pretty much everything they sold that made over 300 HP, so if reliability is a concern...
Can you run a cast crank in a relatively stout combo? Sure. It's more a matter of how long you intend on running it.
malibu795
1,496
4
spgfd ohio
crank and rods are cast... rods running 3/8" bolts.. both are getting cut and/or re-sized
i think i am keeping the 208/218* .475/.500 cam that is in the motor i have running right now.
300rwhp will be a nice DD
wagonmaster
72
Green Bay, WI
Stock crank and rods will handle your goals. Don't worry about a 30 under crank. Tests have shown when correctly ground there is little difference in strength. Radius' done right are the key. Rods are forged. Put ARP bolts in the when reconditioning. Take it to a shop that is usually busy. I have seen many cast steel cranks take a poop and would not run one. Keith blacks should be fine unless you spray. Spend money on good machine work. "0" decking the block, ARP main bolts or studs and align honing, I would balance too if its the budget. Ask the shop if they can do these things too. Don't be shy, its your motor or grenade.
malibu795
1,496
4
spgfd ohio
im looking at keeping it 87 friendly.. looking at KB202 FT or KB203 with a -12cc dome.
block already had ~.004" off.. taking it down so the pistons are .010" in the whole and running a .019 gasket.
with 113cc head and a 4.37x.019 HG and 202 im lookign at high 8.8:1 with 203 im looking at mid 9.5:1
the folowing is getting done
bore
decked
line bored.... mains were .003" out
crank cut
rods re-sized
piston hung... might do this my self... dont know yet
and all of it balanced.
