Post new topic Reply to topic  [ 9 posts ]
 Post Posted: Tue Mar 20, 2018 9:18 am
Did GM ever make a good factory 30 spline 8.5 posi. i think my factory auburn has finally went.
IM ALL JACKED UP ON MOUNTAIN DEW!!!
81 malibu 2dr 350 with vortec heads .40 over, th350 3500 stall, gn 8.5 posi 3.42
12.97@101.67 on motor and 11.80@112.27 on a 150hp shot of nitrous
street beater
Rusty but Trusty
 Post Posted: Tue Mar 20, 2018 2:08 pm
are you sure yours is 30 and not 28 ? I don't know the answer to your question because I've only seen 30 spline in 4x4 trucks and they usually have a govloc. If you indeed need a 30 spline posi I would go aftermarket. Eaton, Auburn or a powertrax lockrite in an open carrier are some options.
brian
What does it profit a man if he gains the whole world and loses is own soul?
http://therocketshop.blogspot.com/
 Post Posted: Wed Mar 21, 2018 11:58 am
I do have a 30 spline posi with aftermarket moser axles. My posi came out of a mid 90s caprice witch do have 30 spline axles. I'm just wondering if they made any better posi units that are factory?
street beater
Rusty but Trusty
 Post Posted: Wed Mar 21, 2018 2:47 pm
I would bet the aftermarket limited slips are stronger then GM.
Doug
1978 El camino
1981 Malibu SS
 Post Posted: Wed May 15, 2019 9:43 pm
I'm planning on a Detroit Truetrac whenever I build the 8.5 I have. No clutches and should hold up fine for the street, if I raced I would probably get the Detroit Locker, to my understanding it's stronger than the Truetrac.
https://www.eaton.com/us/en-us/products ... tials.html
MR.com Facebook page
'87 Fiero GT - 2.8/5-speed
 Post Posted: Sun May 26, 2019 10:02 am
Truetracs are kind of weird. Most gear style limited slip diffs are. They sometimes growl or make funny noises, they sometimes make the car feel loose or move around when you lift off the gas in a corner. My new STi has a gear diff in the back and it does the same things as all lthe other gear diffs I've driven.
 Post Posted: Mon May 27, 2019 6:35 pm
The true track is definitely "different" in feel from regular clutch/cone posi..
Dodge uses the torsion diff design in there 2500/3500 trucks exclusively.
Never had one make noise... Had a ratchet diff make noise but that's not a torsion doff
adam wildman USN vet
79 malibu wagon 454bbc T-56 7.5/8.8 hybrid 3.08
99 C3500HD dmax/4L85
smooth seas never made a skillfull salior
 Post Posted: Wed May 29, 2019 7:39 pm
Auburn has a cheaper one and a better one. Not sure what differences there are besides price.
 Post Posted: Tue Jun 04, 2019 9:03 pm
X2. Everybody goes for the Eaton, but the Auburn Pro series has much higher torque biasing.
