I have seen many different answers on the 12 bolt swap. Will this work with just the control arm swap kit or will the shock brackets and spring brackets need to be moved as well? I have also seen that you will need a new driveshaft and then others say just a different u joint. So what is the real answer? Thanks to all who help in advance.
