Self alinging roller rockers? ? ? ? ' s
dickeymoore
818
Atlanta,Ga.
I have a set of comp cams ultra pro roller rockers (part # 1618-16) and was wondering can I run these self alinging roller rockers on some edelbrock e-tec heads if I remove the guide plates from the heads I have heard that you can't use self alinging rockers with guide plates? THANKS
YAV8
155
Manitiowc, Wisconsin
You sure can do that with out a problem. You might need a few washers under the studs to keep the studs at the same hight as the guide plate. Just be sure that the guides on the rockers are not hitting the retainers on the valve springs.
