SBC 406 compression ratio? ???'s
dickeymoore
818
Atlanta,Ga.
I have a sbc 400 (bored. 30)406 with speed pro forged piston (part#L2489F) with sbc vortec heads on it now and will be swapping the 64cc vortec heads out to gm performance fastburn 62cc heads what will my compression be with the fastburn heads, block is stock deck using a. 39" headgaskets? THANKS
bracketchev1221
1,111
Mountville Pa
You also need to know piston to deck clearance for an accurate number. Zero deck to .020 in the hole can change compression by up to .75 of a number depending on bore size.
