Post new topic Reply to topic  [ 7 posts ]
 Post Posted: Sat Nov 12, 2011 11:16 pm
do you guys think this is to much cam for my 355 street/strip car mostly strip
i have an 10:1 comoression sbc 355 with rhs 220cc heads victor jr intake 750 holley hp carb th350 4200 stall 4:10 gears
1979 Malibu
406 6 inch rods kb .150 dome pistons
hurricane intake 750 dp
doug herbert solid cam 290/300 528/552
chevy 461 heads
NOS Cheater system
Th350, 3500 converter
4.56 gear ratio
28 inch M/T ET Streets
 Post Posted: Sat Nov 12, 2011 11:18 pm
o i almost forgot plus an 200 shot nos system :D
1979 Malibu
chevy 461 heads
NOS Cheater system
4.56 gear ratio
 Post Posted: Sun Nov 13, 2011 7:35 am
What cam?? I think the heads are too big.
 Post Posted: Mon Nov 14, 2011 2:55 pm
What cam is it?
http://s30.photobucket.com/albums/c306/ ... C01615.jpg
My old 78
http://s30.photobucket.com/albums/c306/ ... usquet.jpg
 Post Posted: Mon Nov 28, 2011 11:13 am
Solid roller, rough idle. Excellent cam for serious Pro street/bracket applications. Excellent mid to upper RPM torque and horsepower in 383-406 cubic inch engines. Needs 3500 RPM stall speed converter, 10.5:1 or better compression, aftermarket exhaust system and 4.11 rear gear ratio.
•Advertised Duration (Int/Exh): 285/293
•Duration @ .050 (Int/Exh): 255/263
•Gross Valve Lift (Int/Exh): .600/.600
•LSA/ICL: 110/106
•Valve Lash (Int/Exh): 016/016
•RPM Range: 3000-7200
•Includes: Cam Only
Part Number: 60134
1979 Malibu
chevy 461 heads
NOS Cheater system
4.56 gear ratio
 Post Posted: Mon Nov 28, 2011 9:42 pm
given that you will e spending some time on the street, i think you could go with a bit less duration and not sacrifice any area under the curve.
 Post Posted: Tue Nov 29, 2011 10:56 am
I like the cam and it should work well at the track - lot of cam for the street and so is a 4200 stall. Your intake runners are too big especially a 355. I'm not a nitrous person but with a 200 shot I would think you would like to have a little more lob sep - maybe some nitrous guys can pipe in.
Users browsing this forum: Google [Bot] and 1 guest
cron
