Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: help with a spool ?
 Post Posted: Tue Apr 26, 2011 12:28 am
i have a quick performance ford 9 inch , whats the difference between a full spool and a mini spool ?
" IF YOU AINT FIRST YOUR LAST "
 Post subject: Re: help with a spool ?
 Post Posted: Tue Apr 26, 2011 9:18 am
a full spool is one piece that replaces your carrier, holds the ring gear, and keeps both axles in a constant drive mode. a mini spool replaces the spider gears in an open carrier to keep both axles in a constant drive mode, but they're made from about 3 different pieces and are not as strong as a full spool. mini spools are recommended for dirt track applications mostly, where there isn't enough traction to break them. after running a minispool for a couple seasons, i understand why they're not the greatest for street/strip use.
 Post Posted: Tue Apr 26, 2011 1:46 pm
so for street/strip its better to use a full spool ?
 Post Posted: Tue Apr 26, 2011 2:21 pm
well it depends on what you'll mostly be using the car for..street driving or drag racing..I hear spools can be hard on the street, since both wheels are always moving at the same speed taking turns can be difficult and put strain on the spool. Thats why a lot of people get Tru-trac, open differential for just cruising around town, but 2 wheel power when you lay into it.
It's a wagon thing, you wouldn't understand
 Post Posted: Tue Apr 26, 2011 3:19 pm
well im going to be driving this car more on the street than the track but i will be taking it to the track . i have a mini spool but i dont know what would be better to go with ? what do you think ?
 Post Posted: Tue Apr 26, 2011 4:56 pm
how much street driving will you be doing?
 Post Posted: Tue Apr 26, 2011 6:08 pm
well its pretty much a weekend car but everytime i drive it will be on the street taking it to hangouts the beach car shows . i will only be taking it to the track once in a while to see what time it runs .
 Post Posted: Tue Apr 26, 2011 6:23 pm
i tihnk i'd get a posi or locker of some sort.
 Post Posted: Tue Apr 26, 2011 7:31 pm
yeah. I would go with a posi since your planning for a lot of street use.
 Post Posted: Tue Apr 26, 2011 7:49 pm
Spools suck on the street too dangerous IMO. I had one.
80 Malibu. 496 pump gas.
10.09@132 N/A
6.33@109 n/a 1.38 60ft. With South Side bars!
9.75@135 100 shot.
A stupid question is better than a stupid mistake!
 Post Posted: Tue Apr 26, 2011 9:13 pm
Detroit tru trac is great on the street, had one for 2 seasons. Car drives good, and lights up both tires on demand. QP sells them, they set up my center section for my rear
"Any man can restore a car, it takes a real man to cut one up"
"If speed kills, drive a Honda and live forever!"
'83 El Camino SS, 468 BBC, M22 4 speed, Quick performance 9" with disc brakes, 3.70 posi (4 year build and counting)
'09 Hemi Ram
'67 GTX Convertible 440-sold
 Post Posted: Tue Apr 26, 2011 9:19 pm
ok thanks for all the input guys its been a big help
 Post Posted: Wed Apr 27, 2011 12:07 pm
spool...
pump gas,3880 pound,9.43@141.8 1.24 60 foot, not your grandmas gp
2012 hot rod magazine drag week,3rd place small block power adder
You'd give it all up for what's there for the taking
Whatever it takes to keep your hands from shaking
The same things you're thinking might make you feel better
The same things that probably got you here
 Post Posted: Wed Apr 27, 2011 12:31 pm
Al
'72 Elky - 11.79 @ 118 MPH (Sold :( )
'81 Elky - Hopefully getting quicker
 Post Posted: Wed Apr 27, 2011 8:25 pm
slimbo5 and al , are you guys saying i should run the mini spool i got ?
