Board index » TECHNICAL » Drivetrain Technical
Post new topic Reply to topic  [ 3 posts ]
 Post Posted: Fri Sep 14, 2018 2:04 pm
I just finished putting a 2004r in my 78 El Camino. How do you tell if everything is working correctly?
 Post Posted: Fri Sep 14, 2018 10:10 pm
the important thing with the 2004r 's is the set up of the detent cable.if set up incorrectly the shift timing will be off and the transmission will ultimately fail.
rotisserie-mod
82 el camino
406/200r4
 Post Posted: Sat Sep 15, 2018 8:26 pm
Thank you. With the gas pedal to the floor, the cable is tight. I hope that's correct.
