Board index » TECHNICAL » Drivetrain Technical
Post new topic Reply to topic  [ 6 posts ]
 Post subject: Borg Warner t56
 Post Posted: Mon Jul 02, 2018 2:06 pm
Will a Borg Warner t56 that was in a 73 Camaro fit a 78 El Camino? My78 has an engine from a 73 El Camino. Will I need to shorten the drive line?
 Post subject: Re: Borg Warner t56
 Post Posted: Mon Jul 02, 2018 11:32 pm
This is a 1995 Borg Warner t56 that was in a 95 Camaro, then placed in a 73 Camaro.
 Post Posted: Tue Jul 03, 2018 3:08 am
Yep you will need to use either the clutch linkage for a GBody and a clutch pedal.
or the Camaro slave cylinder along with an aftermarket clutch pedal
1980 Malibu BBC T-56 9"
1986 Oldsmobile Cutlass.
 Post Posted: Tue Jul 03, 2018 7:41 am
Thank you. I appreciate your help. Do you know what cross member it will take?
 Post Posted: Tue Jul 03, 2018 2:34 pm
one made for a T56 into a gbody
gforce makes them as do others, you will also need the frame extension for the Xmember
I forgot about that.
 Post Posted: Tue Jul 03, 2018 2:40 pm
Thanks I'll check that out.
cron
