Board index » GENERAL » MalibuRacing Father/Son Project
Post new topic Reply to topic  [ 7 posts ]
 Post subject: A/C Bracket Finished
 Post Posted: Fri Dec 12, 2008 5:56 pm
MalibuRacing.com Founder
Here's what it looks like:
Side view:
I had to "turn" the water neck towards the front. It was angled toward where the "new" A/C compressor is located now. I had to heat it up with a torch, then install a large bar inside the waterneck and turn it toward the center of the engine. You can also see the brace I had to fabricate out of pieces I had lying around.
Here is a closeup of the rear brace I fabricated. It's not pretty, but it works....
I needed a non-grooved pulley below the compressor to clear the thermostat housing. I found this one at the junk yard. I had to use some hardened washers behind it to get the correct location:
I took a piece of wire and simulated where the serpentine belt will run. I then measured the length of the wire. It was 105.5" long. I went to the part store and got a belt 104.5" long to compensate for the tensioner. I think I should have made it one inch longer, because it is too short. I think I should have got one 106.5" long.... Anyway, I didn't get the belt installed. Back to the parts store.
Here's what the serpentine path will look like:
Also, I removed the fan shroud to prepare for an electric fan install. I need to find a spanner wrench to help remove the clutch fan assembly.
OK, that's all for now....
 Post subject: Re: A/C Bracket Finished
 Post Posted: Fri Dec 12, 2008 8:24 pm
lookin good. looks factory. nice to see some progress.
 Post Posted: Wed Dec 17, 2008 7:43 pm
A/C <----- WHAT IS THIS :mrgreen: :mrgreen: :lol: :lol:
 Post Posted: Wed Dec 17, 2008 8:11 pm
that does look like a very nice setup, can't wait to see more
1978 Chevy Malibu Classic: 350 Crate Swap, Turbo 350 Transmission, Flowtech Full length Headers, Flowmaster Series 40 mufflers, Tru-Dual Exhaust, Northern Autoparts Racing Aluminum Radiator, Goodmark 2in Cowl Hood, Jasper Pearl Paint Job, Pioneer Receiver with Pioneer 6x9 speakers, Billet Specialities Vintec Wheels
 Post Posted: Fri Dec 19, 2008 11:23 am
Looking good Phill. =D>
The Adrenalin Rush Starts Here !!!
 Post Posted: Tue Nov 01, 2011 11:34 pm
Im just starting my LS sway & I have been reading through all your updates. I have a ton of questions but I will ask them in my own thread but wonder if the bracket/Compressor you used would fit on a setup using these accessories...
 Post Posted: Tue Dec 06, 2011 12:38 pm
I know this post is old, but if anyone can give me some tips on rotating the elbow for the water pump, I would appreciate it. I am doing this mod, and tried heating up the water pump at the base of the elbow, but couldn't get it to budge. How hot do you have to get it? Thanks!
cron
