Board index » GENERAL » MalibuRacing Father/Son Project
Post new topic Reply to topic  [ 12 posts ]
 Post Posted: Mon May 05, 2008 1:27 pm
MalibuRacing.com Founder
Sorry for the long delay in updating. Softball season has started and I'm coaching my daughter's team, so we have been very busy. Along with all the usual spring time chores around the house. OK, so enough excuses.....
We got the Moroso pan, and finally got the motor and tranny installed. The transmission "ice"member is bolted in. I haven't finalized the permanent location of the motor. It is currently sitting almost completely up against the heater box. I will probably need to move it forward about 1/2", just to make sure it has enough clearance between the cylinder head and the heater box. I should still have plenty of clearance for the power steering pulley to clear the steering box after moving it forward slightly. Anyway, here are some pictures:
My son installing the Moroso P/N 20140 oilpan:
The motor in:
I found this very cool lift plate on the internet. It made the job MUCH easier to drop the motor into place. Before I got this lift plate, I was having trouble with the mounting hook (bolted to the head)that I had the hoist chain connected to interferring with the firewall. With this setup, I could get the motor as far back as I wanted without any problems. I got it off Ebay from a company called Car Shop Inc. It was $49+12 shipping. It's cheaper on Ebay than buying off their website:
Here you can see the Moroso pan is ABOVE the crossmember, so I don't have to worry about my son hitting it on something. This was an issue with the stock truck pan. The CTS-V would have probably hung about 1/2" below the crossmember. I'm not really sure because I never got it installed with the tranny connected to give an accurate mounting position. Anyway, I was able to get the motor and tranny dropped in together with the Moroso pan. It took some wrestling, but I got both in together. I definitely could not have done this with the truck pan and probably not with the CTS-V pan. I would have to drop the motor-only in first, then install the tranny from underneath if using either of the "factory" pans. Here's the picture:
Another angle:
OK, that's it for now. We plan on cleaning some of the engine components/brackets, re-installing the intake, finalizing the motor location, dropping the fuel tank and installing an EFI tank with EFI pump and plumb, sending the harness and ECM off to get reprogrammed and factory wiring harness cleaned up (got lazy decided to let someone else do it), install A/C compressor in alternate location, blah, blah, blah. In other words, a long way to go. I will be sending off the wiring harness and ECM this week.
For those interested, here is a comparison of the truck and CTS-V oilpan:
CTS-V pan (for sale, BTW!):
Sump Height comparison:
Bottom:
Side:
 Post Posted: Mon May 05, 2008 4:24 pm
what would be the problem using the f body pan? you might have mentioned it but i was not following along .
 Post Posted: Mon May 05, 2008 4:52 pm
An F-body pan would have to be modified to work. I really didn't want to modify a pan to fit. Plus, I would have to buy one, then pay about as much as the pan costs to have it modified. Also, since Landon (roller406bu) is using the Moroso pan and the same transdapt motor mounts, I knew it would work without a doubt. I was hoping the CTS-V pan would work, and it may have. I just got tired of wrestling with it, and decided to go with what I know works.
There's more than one way to skin a cat. ;) Unfortunately, I tried 3 ways before finding one I liked. As Landon pointed out in a previous post, it's been done so quit making it more difficult than it needs to be (or something like that). I finally took his advice and used what is proven.
 Post Posted: Mon May 05, 2008 5:56 pm
keep it going man nice progress
"Racing makes heroin addiction look like a vague longing for something salty."
Cody
Your Grandmas 1979 Malibu, wanna race?
Project Total Swap Thread: http://www.maliburacing.com/forum/viewtopic.php?t=54543
Automatics win races, 6-speeds impress high school kids
 Post Posted: Mon May 05, 2008 11:46 pm
Have you researched the corvette filter/regulator setup? Thats what Im going with, I could dig some links up if needed....
2002 C5 ECS glide no motor yet.
2000 SS Camaro
1980 Malibu
1970 Nova
 Post Posted: Tue May 06, 2008 6:19 am
Yes please! I hadn't considered that. Is that off the LS7?
Thanks
 Post Posted: Tue May 06, 2008 10:57 pm
looking good phillip!
You've always been taking
And now your giving.
Seek and Destroy
 Post Posted: Mon May 12, 2008 3:12 pm
what headers are u going to use ?
 Post Posted: Thu May 15, 2008 7:01 am
1978 Malibu, carbed 6.0, MS4 cam, trickflow 220's, Edelbrock Plate....
2002 Transam WS-6 G5x3, fast 90, 4.30's, Speed-density tuned
1986 Mustang GT
 Post Posted: Fri May 16, 2008 6:25 pm
Thanks.
I'm using factory F-body exhaust manifolds. I don't want to deal with headers on a daily driver. I'm wanting an "OEM" look when I get finished.
 Post Posted: Fri Oct 03, 2008 10:57 pm
Are the truck manifolds definatly not going to fit?
 Post Posted: Mon Oct 06, 2008 12:52 pm
The drivers side DEFINITELY will NOT fit.
