Board index » TECHNICAL » Power Adders
Post new topic Reply to topic  [ 12 posts ]
 Post Posted: Tue Feb 02, 2016 3:07 pm
so this would be my first car that i would like to put some Nos on and i need suggestions on how much it can handle the specs on the motor are as follows:
-The engine is a ZZ4 crate engine with Fast Burn heads & LT4 HOT cam. Induction is an Edelbrock RPM Air-Gap with a Holley 770 Street Avenger vacuum secondary carb.
- The Fuel System consists of a Holley Black fuel pump and regulator
- Ignition is Performance Distributors HEI/ MSD box
- TH350 with the 1-2 shif kit no trans break and stock converter
- GN 8.5 373 posi
- Main question is, can i piggy back of the main elec pump, or should i run a separate cell and pump?
- wat kinda system would work better for the street? plate or fogger?
thanks in advance
 Post Posted: Tue Feb 02, 2016 4:18 pm
that black pump will supply enough fuel. Others may not agree but i've done it and with alot more motor than you have. Two regulators is a good idea. Does it have forged pistons?
Brian
What does it profit a man if he gains the whole world and loses is own soul?
http://therocketshop.blogspot.com/
 Post Posted: Tue Feb 02, 2016 11:05 pm
thanks for the answer, i didn't build the motor, so I'm not sure if it has forged pistons
Brian
 Post Posted: Wed May 18, 2016 7:44 pm
Unless they have been changed out, the zz4 has hyper-u-tectic pistons. As far as the fuel, I agree with Prairie. How much do you intent to inject? Timing with those pistons is a lil bit more critical.
 Post Posted: Thu May 19, 2016 10:23 am
this is where the debate begins....lol. hypereutectic pistons and nitrous don't mix in a lot of people's opinion. others say you can spray ANYTHING with a 150 HP shot. i guess it depends on your risk tolerance.
 Post Posted: Sat May 21, 2016 1:11 pm
Not arguing that and I agree with what you are saying. I wouldn't be afraid to spray that with cast stockers either but you still need to dial in your timing, that's all I'm saying.
 Post Posted: Sun May 22, 2016 12:32 am
Hit it with 150 max. Pull 6 deg of timing. Run a separate regulator for the N20, you should always check flowing fuel pressure and have 5 psi min. Ideally you want a stand alone fuel system but you can run it with one. Dont engage it under 3 k rpm, Try to keep bottle pressure around 950 psi. Go a couple steps colder on the plugs (non projected tip).
80 Malibu. 496 pump gas.
10.09@132 N/A
6.33@109 n/a 1.38 60ft. With South Side bars!
9.75@135 100 shot.
A stupid question is better than a stupid mistake!
 Post Posted: Tue May 24, 2016 10:26 am
I wasn't really replying to your post. You're absolutely correct though. Better have your tune right with those pistons.
 Post Posted: Sat Jun 04, 2016 11:39 pm
I have a 383 with hypers. Sprayed for a couple years with a 100 shot pulling 4 degs. of timing out. Just sprayed it last week with a 150 shot pulling 6 degs. of timing out. I have a separate 1 gal. fuel cell and pump up front for the NOS. I installed a window switch, sprays 2800 to 6000 rpm's. Colder plugs.
 Post Posted: Mon Jun 06, 2016 9:55 pm
Could you post some pics of your stand alone fuel system? I'd like to set something like that up on my car.
 Post Posted: Mon Jun 06, 2016 10:52 pm
 Post Posted: Tue Jun 07, 2016 4:23 pm
Thanks for sharing new2malibu.
