Board index » TECHNICAL » Power Adders
Post new topic Reply to topic  [ 6 posts ]
 Post Posted: Mon Apr 20, 2015 1:30 pm
I currently have a fresh rebuilt 350 all new inside componets with a Howard 505 cam.(mild) B&M 144 super charger (just rebuilt) with an Edelbrock 750 carb. Not really happy with the performance thought I would get more out of the motor and not sure if the carb is part of the problem. Considering swapping to the Holly 750 super charger carb. Any thoughts? Is it worth spending the money? Could it be a noticeable difference?
 Post Posted: Tue Apr 21, 2015 11:54 am
I run a B&M 162 supercharger and with these their is no need for a supercharger carb per say, they recommend a boost reference carb but these don't produce enough boost to warrant it. I use a 750 speed demon and this thing works great.
Just grab a double pump holley or a demon and scrap that edelbrock, you'll be happier.
If you need any material on these blowers, let me know and i could help you with what i have.
350 .060 over
dart pro 1's
B&M 162 blower
750 demon
turbo 350 3500 stall
12 bolt 456 gears
 Post Posted: Sat Apr 25, 2015 12:48 pm
750 Holly double pumper it is.
Thanks Bowtie
 Post Posted: Sun Apr 26, 2015 7:17 pm
no prob buddy, let me know if you need the instruction manual.
350 .060 over
dart pro 1's
B&M 162 blower
750 demon
12 bolt 456 gears
 Post Posted: Mon Jun 15, 2015 8:29 pm
Newbie
I strongly recommend boost reference that holley. its very easy to do. if not then remove/plug the pv and fatten it up. if you run a pv on top of the 144 it will never open and not richen it poss run to lean not good...and buy a fast afr meter # 170402 money well spent and save u lots of headaches
 Post Posted: Mon Jun 15, 2015 10:36 pm
I cant help with the supercharger tuning but I can tell you the Holley is a much better choice when tuning for max h.p. And Like was already said A wideband afr is money well spent.
80 Malibu. 496 pump gas.
10.09@132 N/A
6.33@109 n/a 1.38 60ft. With South Side bars!
9.75@135 100 shot.
A stupid question is better than a stupid mistake!
